How to create a Neural Capture on Nano Cortex
In this guide, we'll walk you through the step-by-step process of creating Neural Captures on your Nano Cortex.
Neural Capture is a powerful feature that allows you to create incredibly accurate digital replicas of any physical amplifier, cabinet, or drive pedal for use on both Nano Cortex and Quad Cortex. Neural Captures created on Nano Cortex are the same quality and resolution as those created on Quad Cortex.
Creating a Neural Capture on Nano Cortex is fast and easy. The whole process lasts about five minutes and is carried out entirely on-device. This means that there is no need to connect to a computer, the internet, or the Cortex Cloud app.
However, the specific steps for creating Neural Captures will vary slightly depending on the type of hardware you're working with. In the upcoming sections of this guide, we will cover the steps for creating Neural Captures of:
  • A drive pedal
  • An amp+cab or combo amp
  • An amp head with no speaker
Initial setup
Connecting your instrument and monitoring devices
Before beginning the Capture process, you will need to connect your instrument and monitoring devices to Nano Cortex.
Step 1: Plug your guitar/bass to INPUT 1 using a standard 1/4" instrument cable.
Step 2: Connect your headphones to HP OUTPUT and/or a studio monitor to OUTPUT 1L.
Turn on Capture Mode
After connecting your instrument and monitoring device(s) to Nano Cortex, turn on Capture Mode.
Step 1: Press CAPTURE to turn on Capture Mode. When in Capture Mode, the CAPTURE LED ring will stay on.
Note: Press EXIT to return to Performance Mode.
Capturing a drive pedal
You can create Neural Captures of overdrive, distortion, and fuzz pedals. By doing this, you can use the Nano Cortex as a compact device that can store up to 256 incredibly accurate digital replicas of your favorite drive pedals. The setup process is straightforward and can be done very quickly.
Instructions for creating a Neural Capture of a drive pedal
A. Initial setup
Step 1: Connect your drive pedal to Nano Cortex
  • Connect OUTPUT 2R (CAPTURE OUT) on the Nano Cortex to the input of your drive pedal.
  • Connect the output of the drive pedal back to the CAPTURE INPUT on the Nano Cortex.
Step 2: Connect your monitoring device(s)
  • If you haven’t already, connect your headphones to HP OUTPUT and/or a studio monitor to OUTPUT 1L to monitor your Capture.
Step 3: Connect your instrument to Nano Cortex
  • If you haven’t already, plug your guitar/bass to INPUT 1 using a standard 1/4" instrument cable.
Step 4: Turn on Capture Mode
  • If you haven’t already, press CAPTURE to turn on Capture Mode. When in Capture Mode, the CAPTURE LED ring will stay on.
B. Set CAPTURE INPUT levels
Optimizing the CAPTURE INPUT level is very important for creating an accurate Neural Capture. Follow these steps to adjust and optimize the CAPTURE INPUT level.
Step 1: Adjust the CAPTURE INPUT level with the GAIN knob
  • Strum your instrument while watching the GAIN knob meter.
  • Adjust the GAIN knob to set the input level. If the signal level remains too low after adjusting the GAIN knob, you can engage the BOOST switch to increase the input gain by +26dB:
    • Green: Indicates a healthy level
    • Blue: Indicates the level is too low. Increase the GAIN or turn on the BOOST switch to increase the input gain by +26dB and compensate for the low level.
    • Red: Indicates clipping, meaning the signal is too strong. Turn off the BOOST switch or reduce the output level of the target device until the signal level is correct (Green LEDs).
Important: Ensure the GAIN knob is set to its minimum position (0%) before engaging the BOOST switch.
C. Start the Capture
Step 1: Start the Capture process
  • Once the CAPTURE INPUT level has been set to a healthy level, press and hold the CAPTURE button for 3 seconds to start the capture process.
Step 2: Wait for the Capture to complete
  • Nano Cortex will run through a series of test tones and measurements. This process typically takes about 5 minutes. During this time, Nano Cortex is analyzing the response of your drive pedal and training a neural network to replicate its sound.
  • Important: During the capture process, avoid adjusting your setup to ensure an accurate capture.
D. Test and save your Neural Capture
Step 1: A/B test your Capture
  • After the Capture process is complete, use Footswitch I to toggle between the captured sound and the original drive pedal. The LED will light up green for the Capture and will be off for the original.
  • When auditioning your recently created Neural Capture, turn Footswitch II clockwise or counterclockwise to navigate IR Slots. The LEDs will light up according to the slot selected.
    • Tip: You can bypass the IR Loader by navigating to the last position, where the LEDs are not lit. This is especially recommended when auditioning a Capture that includes a speaker cabinet.
  • When testing your Capture, you can press Footswitch II to bypass Nano Cortex.
Step 2: Save your Neural Capture
  • Press the SAVE button to begin storing your Capture. The BANK and Capture Slots LEDs will start blinking, indicating that you can now select a slot for storage.
Step 3: Select a Capture Slot to save your Capture:
  • Cycle through the banks and choose a Capture Slot:
    • Press the BANK button to cycle through the banks. Each bank contains multiple slots where you can store your Capture.
    • Turn Footswitch I clockwise or counterclockwise to navigate through the available Capture slots within the selected bank.
  • Tip: If you want to save your Capture without assigning it to a specific slot, navigate to the position where all the LEDs are lit. This corresponds to the User Library, where you can store the Capture for later use.
Step 4: Confirm and Save:
  • Once you’ve selected your desired bank and slot, press and hold the SAVE button for 3 seconds to confirm and store your Neural Capture.
Step 5: Return to calibration settings or Performance Mode:
  • After saving your Capture, press EXIT to return to the calibration settings if you wish to start a new Capture process.
  • Press EXIT again to return to Performance Mode and start playing with your newly created Capture.
Capturing an amp+cab or combo amp
You can create Neural Captures of an amp and cab setup, or a combo amp, to create incredibly accurate digital replicas of your favorite amplifier and speaker combinations.
When capturing an amp+cab or combo amp with Nano Cortex, you’ll need to use a microphone to capture the sound. The type of microphone you’re using and its placement relative to the cabinet will significantly affect the captured tone. Neural Capture is a snapshot of your entire setup, including the microphone and its position, so careful mic placement is essential.
Common microphones used for capturing amp and cab setups include the Shure® SM57, Sennheiser® e609, and Royer® R-121.
Note: Nano Cortex’s CAPTURE INPUT supports dynamic microphones directly. If you’re using a condenser microphone, you’ll need an external preamp to power it.
Instructions for creating a Neural Capture of an amp+cab or combo amp
A. Initial setup
Step 1: Connect your amp+cab or amp combo to Nano Cortex
  • Connect  OUTPUT 2R (CAPTURE OUT) on Nano Cortex to the input of your amp using a standard 1/4" instrument cable.
Step 2: Position your microphone and connect it to Nano Cortex
  • Position your microphone in front of the speaker cabinet and connect it to Nano Cortex's CAPTURE INPUT.
  • Begin by setting the microphone at a 90-degree angle to the speaker cone, pointing directly towards the center of it. Position it around one inch away from the speaker grill. If the speaker cone is not visible through the grill material of the cab, shine a flashlight onto it to help find its position.
    • Moving the mic toward the outer edge reduces midrange and upper-mids.
    • Closer placement increases bass response and focus.
    • Positioning the mic at a 45-degree angle (off-axis) warms the tone and reduces highs, while an on-axis position brightens the tone.
    • Note: There are no fixed rules for microphone placement. Trust your ears and experiment with different positions until you find the tone you’re looking for.
Step 3: Connect your monitoring device(s)
Step 4: Connect your instrument to Nano Cortex
Step 5: Turn on Capture Mode
B. Set the CAPTURE INPUT levels
  • After the Capture process is complete, use Footswitch I to toggle between the captured sound and the original amp and cab. The LED will light up green for the Capture and will be off for the original.
Capturing an amp head without a cab
You can create Neural Captures of amp heads to digitally preserve and recreate the unique tone of your favorite amplifiers. Your Captures can then be paired with the built-in IR Loader on your Nano Cortex to simulate the sound of a full amp and cab setup.
Creating Neural Captures of amp heads is particularly useful for getting a consistent, portable, and versatile tone that you can take anywhere.
Important: When capturing an amp head without a cab, you’ll need to use a reactive load box to safely manage the amp’s output. Connecting the speaker output of a tube amplifier to Nano Cortex without a reactive load box could damage both devices.
Common reactive load boxes for capturing amp heads include the Two Notes® Torpedo Captor, Suhr® Reactive Load IR, Fryette® Power Station, Universal Audio® OX Amp Top Box, and Radial® Headload Prodigy.
Note: If your amp has a D.I. out, you can connect to that provided your amplifier is still connected to a cabinet.
Instructions for creating a Neural Capture of an amp head without a cab
A. Initial setup
Step 1: Connect your amp head to Nano Cortex
  • Connecting your amp head to Nano Cortex with a reactive load box
    • Connect  OUTPUT 2R (CAPTURE OUT) on the Nano Cortex to the input of your amp using a standard 1/4" instrument cable.
    • Connect the amp’s speaker output to the speaker input of your reactive load box
    • Connect your reactive load box's balanced output to the Nano Cortex's CAPTURE INPUT.
Or
  • Connecting your amp head to Nano Cortex using the D.I. out of your amp head
    • Connect the amp’s D.I. output to the Nano Cortex's CAPTURE INPUT
      • Important: Ensure your amp head is still connected to a cabinet to avoid damaging your equipment.
  • If you haven’t already, plug your guitar/bass to INPUT 1 using an instrument cable.
  • After the Capture process is complete, use Footswitch I to toggle between the captured sound and the original head. The LED will light up green for the Capture and will be off for the original.
Creating a Neural Capture with the Cortex Cloud App
While you can create a Neural Capture directly on your Nano Cortex, using the Cortex Cloud app provides a more guided and user-friendly experience, making the process easier from start to finish.
For detailed instructions on setting up the Cortex Cloud app, read our guide on pairing your Nano Cortex with the Cortex Cloud app and using the app.
How to create a Neural Capture using the Cortex Cloud app
Step 1: Open the Neural Capture tool in the Cortex Cloud App:
  • Tap the contextual menu button at the top-right corner of the app.
  • Select ‘Create New Neural Capture’. This will bring you to the 'Connection Diagram' screen, where you’ll see a visual guide for connecting your gear.
Note: Alternatively, press the CAPTURE button on your Nano Cortex while the Cortex Cloud app is open. The app will skip the 'Connection Diagram' screen and open the 'Calibration Settings' screen.
Step 2: Follow the connection diagram:
The Cortex Cloud app will display a connection diagram showing how to connect your gear, whether it’s a drive pedal, a mic’d up cabinet, or an amp head connected via a reactive load box.
  • Follow the on-screen instructions and connect your gear according to the diagram.
  • After setting up your connections, tap NEXT to proceed.
  • Tip: If you’re already familiar with the setup process, you can tap SKIP to move directly to the 'Calibration Settings' screen.
Step 3: Adjust the calibration settings and begin the Capture process:
In the 'Calibration Settings' screen, you’ll fine-tune your setup to ensure optimal Capture quality.
  • CAPTURE IN GAIN: Drag the slider to adjust the CAPTURE INPUT gain, up to a maximum of +24dB.
  • OUTPUT LEVEL: Use the slider to control the overall output volume of the Nano Cortex, affecting both OUTPUT 1L and your headphones.
  • IR Loader: Tap to toggle the IR Loader on or off, or to change IRs.
Once your settings are dialed in, tap START CAPTURE to begin the capture process.
Step 4: Capture process and adding metadata to your Capture:
During the Capture process, Nano Cortex will analyze your gear by measuring latency and recording signals used for creating the Capture. During this process you can add metadata to your Capture.
  • Add Metadata: During the Capture process, you can add metadata to your Neural Capture, such as Name, Type, Description, and Preferred Instrument.
  • Tap NEXT: Once the capture is complete, tap NEXT to proceed to the ‘Testing’ screen.
Step 5: Test and save your Neural Capture:
In the 'Testing' screen, you can compare the captured sound with the original signal.
  • A/B Compare: Use the monitoring switch to toggle between the target device’s signal and the Neural Capture you created. You can also set it to switch automatically every 2, 4, or 8 seconds.
  • Save your Capture: Tap SAVE TO SLOT to store your Neural Capture in a specific slot, or choose SAVE TO LIBRARY to store it in your library for later use.
Once your Neural Capture is saved, tap DONE to exit Capture Mode, or select CREATE ANOTHER CAPTURE to return to the ‘Calibration Settings’ screen.
Next Steps
By capturing your amplifiers, cabinets, and drive pedals, you can now carry those tones with you, wherever you go, all within your Nano Cortex.
The process of creating Neural Captures is remarkably quick, easy, and straightforward. With just a few simple steps, you can accurately replicate the unique sound of your equipment and have it ready to use at any time.
For more information on how to share your Neural Captures and explore the vast library of Captures created by others, be sure to read our guide on using the Cortex Cloud app. The Cortex Cloud allows you to download Neural Captures from users all around the world, giving you access to a limitless array of tones to try out.
Get your Nano Cortex today
