Massive NanOS 2.0.0 update is now available!
We’re extremely excited to announce the release of NanOS 2.0.0, the biggest update to Nano Cortex since launch.
This free update unlocks the full potential of Nano Cortex with a massively expanded device list, a customizable effects chain, and powerful new features that make it easier than ever to play anywhere without compromising on sound or flexibility.
Watch the Play Anywhere launch video here.
Input Gate
A fixed Input Gate has been added before pre-effects slot 1.
IR Global Bypass
IR is bypassed for all Presets when this setting is enabled. Access via the Settings menu.
Vastly expanded device list
NanOS 2.0.0 greatly expands the available Effects and Utilities, introducing:
3 new EQs
Parametric-3
Low-High Cut
Graphic-9
3 new Utilities
Utility Gate
Volume
Doubler
8 new Compressors
Legendary 87 (M) - Based on Universal Audio® 1176®
Solid State Comp (M) - Based on SSL® Bus
VCA Comp (M)
Opto Comp (M)
Legendary 87 (ST) - Based on Universal Audio® 1176®
Solid State Comp (ST) - Based on SSL® Bus
VCA Comp (ST)
Opto Comp (ST)
4 new Wahs
Bubba Wah - Based on Dunlop® Budda Budwah®
Bass Wah
Crying Wah - Based on Dunlop® Cry Baby® GCB-95®
Crying Clyde Wah - Based on Dunlop® Cry Baby® Clyde McCoy®
2 new Filter Effects
Love Meat - Based on Lovetone® Meatball®
Envelope Filter
9 new Guitar Overdrives
Obsessive Drive - Based on Fulltone® OCD®
OD250 - Based on DOD® Overdrive Preamp 250®
Rodent Drive - Based on ProCo® Rat®
Exotic - Based on Xotic® BB Preamp®
Chief OD1 - Based on BOSS® OD-1®
Chief BD2 - Based on BOSS® BD-2®
Facial Fuzz - Based on Dunlop® Fuzzface®
Exotic Z Boost - Based on Xotic® RC Booster®
Green 808 - Based on Ibanez® TS808®
2 new Bass Overdrives
Microtubes B3K - Based on Darkglass® Microtubes B3K®
Exotic Bass Z Boost - Based on Xotic® RC Bass Booster®
6 new Modulation Effects
MX Flanger - Based on MXR® Flanger M117R®
Dream Chorus (ST) - Based on TC Electronic® Dreamscape®
Chorus 229T - Based on TC Electronic® TC-2290®
Chief CE2W (ST) - Based on BOSS® CE-2W®
MX Phase 95 - Based on MXR® Phase 95®
MX Vibes - Based on MXR® UniVibe®
5 new Delay Effects
Tape Delay (ST)
Digital Delay (ST)
Dual Delay
Dual Reverse Delay
Circular Delay
5 new Reverb Effects
Room
Hall
Modulated
Ambience
Cave
Each device is designed to work in specific Slots within the signal chain.
Devices available in any Pre or Post Effects Slot
EQ (3)
Parametric-3
Low-High Cut
Graphic-9
Devices available in Pre Effects Slots
Utility (3)
Adaptive Gate
Utility Gate
Volume
Compressor (4)
VCA Comp (M)
Opto Comp (M)
Wah (4)
Bass Wah
Filter (2)
Envelope Filter
Guitar Overdrive (9)
Bass Overdrive (2)
Devices available in Pre Effects Slot 1 only
Pitch (1)
Transpose
Devices available in Post Effects Slots
Compressor (4)
VCA Comp (ST)
Opto Comp (ST)
Devices available in Post Effects Slot 1 only
Utility (1)
Doubler
Modulation (7)
Chief DC2W (ST) - Based on BOSS® DC-2W® Dimension
Devices available in Post Effects Slot 2 only
Delay (6)
Tape Delay (ST)
Analog Delay (ST)
Digital Delay (ST)
Dual Delay
Dual Reverse Delay
Circular Delay
Devices available in Post Effects Slot 3 only
Reverb (6)
Room
Hall
Modulated
Ambience
Cave
Mind Hall - Based on Lexicon® 224®
The Transpose device can now only be used in pre-effects slot 1.
A Pitch Fine parameter has been added to the Transpose device.
An issue where the Amount LED ring dimmed immediately when an expression pedal reached the toe position while effects bypass was assigned to the pedal, overriding the configured switch delay value.
An issue where the "412 CA Stand OS V30 01 - Dynamic 57 Off Axis" positions 1 and 2 used the same impulse response (IR) instead of distinct ones.
An issue where a Preset change occurred after disabling 4-Preset Mode while preset 1A or 1B was active.
An issue where the Save button LED did not provide visual feedback and remained off when short-pressed to select a save slot in the Neural Capture Save menu.
An issue where the Amount LED ring did not consistently light up to indicate the enabled state (bright) when using momentary expression switch pedals assigned to Switch with Latch Emulation.
An issue where the Level knob did not function in Latching mode when controlling Capture volume, if the volume had been adjusted in the app prior to entering Capture Volume mode on the pedal.
An issue where a Capture slot LED remained lit after saving a Neural Capture to the Library from within the Neural Capture Save menu.
An issue where the Nano Cortex could be locked from within any of the four Neural Capture Connection Diagram screens.
An issue where the LED on/off states and expression pedal adjustments of multiple parameters were slow and delayed when the pedal was receiving input signal and the EXP treadle was being adjusted.
Various minor bug fixes.
Update now
To experience everything NanOS 2.0.0 has to offer, update your Nano Cortex through the Cortex Cloud app. Read our guide on updating your Nano Cortex for step-by-step instructions.
Visit the Nano Cortex page to learn more and watch the walkthrough videos.
Mantra 1.2.1 is now available
