CorOS 1.0.3 is now available
CorOS 1.0.3 is now available. Download it via Settings > Device Options > Device Updates on your Quad Cortex once connected to Wi-Fi. We recommend that you create a backup before updating your firmware.
Changelog
### Added
Multi-Out is now available on the Grid Output block and is the default setting.
### Changed
All Factory Presets have been updated to use Multi-Out as the default output.
### Fixed
Issue where no mics are listed in the IR menus for guitar cabs added in 1.0.2.
Issue where Neural Capture parameters are set to default values rather than user defaults when adding a new Capture to The Grid.
Issue where all Neural Captures would have their parameter values modified after using the “Set parameters as default” option in the editor.
Crash when changing Preset with an expression pedal connected.
Crash when saving a copy of a Neural Capture when all 256 slots are full in the My Captures folder.
Crash when sending continuous Preset change MIDI messages over several hours.
Minor UI improvements, optimisations, and backend changes.
