Knowledge baseQuad Cortex updatesQuad Cortex Development Update #53 & Plugin Development Update
November 11, 2024
We are pleased to announce that CorOS 3.1.0 is reaching the end of beta, and we expect to be able to release it before the end of November.
CorOS 3.1.0 will bring Fortin Nameless X and Soldano SLO-100 X compatibility to the Quad Cortex, and in addition to the features mentioned in our previous update, we’re delighted to say that the following quality of life improvements made it into this update:
Momentary Footswitch Behavior in Stomp Mode
Stomp Mode now supports momentary footswitch behavior. Configure momentary switch behavior after pressing the “Assign Footswitch” button in the parameter while in Stomp Mode or Hybrid Stomp Mode. Momentary footswitches can also be assigned when renaming Stomps within Gig View.
The Looper X device cannot have momentary footswitch behavior.
When assigning momentary footswitch behavior to the Freeze device, the momentary function triggers the effect rather than the bypass state of the device.
MIDI assignments do not support momentary footswitch behavior.
Import Plugin Presets
It is now possible to import presets from Quad Cortex-compatible plugins via Cortex Control. Simply drag-and-drop compatible plugin preset files from your computer onto a Preset folder in Cortex Control.
Bulk Editing
Bulk edit the names of Presets, Neural Captures, and Impulse Responses via the Directory by selecting multiple items and tapping the “Edit” button. You can also bulk edit metadata for Presets and Neural Captures. Rename Stomp Assignments in Stomp Mode Gig View
Tap the edit button in Gig View while in Stomp Mode to rename the Stomp assignments.
Master Volume Knob Assignments
The Master Volume Knob Assignments now appear when you adjust the Master Volume Knob, allowing you to change the settings without entering the Settings menu.
Future X updates
Archetype: Petrucci X is also reaching the end of beta. The next two plugins to receive X updates will be Archetype: Rabea and Archetype: Tim Henson.
