CorOS 3.2.0 and Cortex Control 1.3.0 are now available
We’re pleased to announce the release of CorOS 3.2.0 and Cortex Control 1.3.0. This update introduces Quad Cortex compatibility for Archetype: Cory Wong X, Archetype: Nolly X, and Parallax X, along with a range of highly requested features and quality-of-life improvements.
To take full advantage of these updates, we recommend that all Quad Cortex users install CorOS 3.2.0 and Cortex Control 1.3.0.
Additional Neural DSP plugins will become Quad Cortex-compatible as their supporting CorOS versions are released.
What’s new in CorOS 3.2.0
New features
Plugin Compatibility for Archetype: Cory Wong X, Archetype: Nolly X, and Parallax X
If you own licenses for these plugins, their devices are now available on Quad Cortex. For details, visit our Plugin Compatibility (PCOM) page.
You can also check the full list of available virtual devices on the Quad Cortex device list page.
Live Tuner
Accessible via the Tuner menu. When activated, it displays at the top of the Gig View.
Metronome
Accessible via the Tempo Menu.
‘Looper X’ Updates:
Pre-Roll: When activated, the Looper X Pre-Roll counts in with the metronome for a specified number of bars before triggering the transition to the next state, such as RECORD or PLAY state.
A 'Metronome Playback' switch now displays in the Looper X parameters.
Loop recording length can be customized, from 1 to 32 bars.
Looper X actions can now be reassigned to different footswitches via the contextual menu.
Sidechain Improvements
A new “Follow Input” setting has been added to Sidechain-compatible devices (S/C). When enabled, this option automatically detects and follows the active input signal from the Input blocks on The Grid. This helps prevent unintended muting when switching between different input sources.
Icons have been added to all available SOURCE and TRIGGER options to make them easier to identify and navigate.
General UX Improvements
Dimmed LEDs settings can now be assigned to all Modes, with adjustable brightness levels for better customization.
Previous/Next navigation arrows have been added to the Scene Editor, allowing quick editing of scene names and colors within the same Preset.
‘ESS’ Codec support
Starting August 2025, Quad Cortex will be manufactured with a new audio codec, due to the original component being discontinued. It’s important to note that this change does not affect or compromise the Quad Cortex’s audio quality.
Quad Cortex “ESS” variants no longer display TYPE Switches for INPUTS 1/2. The signal now reaches both the TS and XLR parts of the Combo inputs, negating the need to select the input type.
Note: In Quad Cortex Development Update #56, we stated that ESS codec support would be included in a separate CorOS update (3.1.1). However, due to last-minute issues identified by our Quality Assurance team, we postponed that release. Once the issues were resolved, CorOS 3.2.0 was nearly complete, so we chose to merge the two updates.
CorOS automatically adapts its ‘I/O Settings’ and ‘Neural Capture Calibration’ layouts based on the Quad Cortex’s codec type (‘Cirrus’ or ‘ESS’).
Sidechain devices in the Factory Presets have had their SOURCE and TRIGGER parameters updated to use the ‘Follow Input’ option by default.
In STOMP mode, tapping a device icon in Gig View now opens its parameter editor on The Grid.
The Settings menu has been reorganized into structured categories for improved accessibility.
The Downloads folders now support Multi-Selection, allowing for bulk actions.
The power function previously labeled ‘STANDBY’ has been renamed to ‘BE RIGHT BACK’.
An issue where an excessive number of items in the Downloads Queue could lead to performance issues or system crashes. The queue is now limited to 200 items on Quad Cortex. Note: This limit does not affect your full Downloads History on Cortex Cloud—all previously downloaded items remain safe and accessible.
An issue where the ‘Recent’ folder was selectable while multi-select was enabled in the ‘Favorites’ folder within the Directory.
An issue where the Splitter became disabled in Crossover mode when the Frequency parameter was turned fully counter-clockwise.
An issue where oscillations and noise could be heard from the ‘Fortin® Nameless’ Amp device when the MVC and Gain controls were set to very high levels.
An issue where a momentary footswitch could end up in the opposite bypass state if held down while changing scenes in Scene/Stomp hybrid mode.
An issue where long Cab device names were cut off within the Cab parameter editor menu in Stomp mode.
An issue where replacing a device set to Momentary mode with a Freeze device would change the switching mode back to Latching.
An issue where the footswitch LEDs would shut off when editing the name of a Stomp in Gig View.
An issue where an additional bank was loaded after releasing the UP Arrow or DOWN Arrow footswitch following a long press in Preset, Scene, or Stomp modes.
An issue where the Source parameter setting would persist when switching between sidechain devices, until a device without a Source parameter was loaded.
An issue where a crash could occur when downloading legacy Cloud Backups.
Addressed several crash scenarios and stability issues.
Various minor bug fixes and performance improvements.
What’s new in Cortex Control 1.3.0
New features
‘ESS’ Codec support
Cortex Control no longer displays ‘TYPE’ Switches for INPUTS 1/2 for Quad Cortex “ESS” variants.
Metronome
Accessible via the ‘TEMPO’ tab in the bottom utility bar.
Automatic Preset IR Import
When importing plugin presets via Cortex Control, any associated User Impulse Responses (IRs) are automatically transferred and imported to the Quad Cortex.
A new “Follow Input” setting has been added to Sidechain-compatible devices (S/C). Additionally, icons have been added to all available SOURCE and TRIGGER options, making it easier to identify and navigate through them.
Plugin Devices
Archetype: Nolly X
Parallax X
Cortex Control automatically adapts its ‘I/O Settings’ and ‘Neural Capture Calibration’ layouts based on the Quad Cortex’s codec type (‘Cirrus’ or ‘ESS’).
The power function ‘STANDBY’ has been renamed to ‘BE RIGHT BACK’.
An issue where the Date Added field displayed ‘31 Dec 1969’ in Cortex Control for presets that were created offline before performing a cloud Backup download.
An issue where the Cortex Control did not display a "Preset already exists" message when attempting to overwrite a single preset already stored in the cloud.
An issue where Splitter/Mixer settings would disappear in Control after dragging a device to Row 2 and then back to Row 1.
An issue where the Looper X would appear to be in Momentary Stomp mode if it replaced another device that was already in that mode.
An issue where footswitch LEDs were not correctly updated after opening Gig View with Cortex Control while a Lane Output Control was open on the Quad Cortex.
An issue where the Source parameter for S/C and Utility devices was not restored when set to an auditioned device and the audition was subsequently cancelled.
An issue where a UI crash could occur when duplicating a large setlist, quickly deleting it, and then duplicating the setlist again in the Directory menu.
An issue where the Neural Capture subfolder appeared empty after navigating to the Directory and then back to the Grid.
An issue where the Global EQ and Input Gate icons showed the incorrect state in Control when they were disabled on the Quad Cortex.
CorOS 3.2.1 and Cortex Control 1.3.1 are now available
