Durability tests! - Quad Cortex Development Update #7
Formerly Quad Cortex Development Update - September 2020
Quad Cortex won’t only be one of the most powerful and versatile audio processing devices ever made; it will also be one of the most reliable. Everything in its construction is designed with precision and durability in mind. To put it through its paces, we took it to a testing facility to see how its components would withstand vibration, temperature, and humidity. Quad Cortex was powered on and had a tone running through it to ensure it continued to produce sound.
Temperature & Humidity Tests
Quad Cortex was placed in a climatic test chamber for 15-minute intervals starting at 0°C (32°F) and 40% humidity. After 15 minutes, the test interval concluded, and the temperature was increased by 10°C. Quad Cortex performed flawlessly at a level expected of military specification components through to 70°C (158°F). At 80°C (176°F), the test was cut short after 10 minutes as the testers had concerns about the internal battery exploding. We also conducted a 15-minute test at 70°C (158°F) and 95% humidity, which Quad Cortex passed with no issues.
Vibration Tests
Quad Cortex was put through three standardized 30-minute vibration tests at random frequencies to match a lorry or van’s vibrations, mild aircraft turbulence, and severe aircraft turbulence. Each of these tests concluded with a 100% pass. We then used a sweeping frequency to find Quad Cortex’s resonant frequency. We put the unit through a series of tests, increasing vibration amplitude up to 20 G. Quad Cortex was operational for the full 40-minute resonant frequency test and passed. Overall, Quad Cortex performed far beyond the level that devices in its category are expected to perform.
CorOS 3.2.1 and Cortex Control 1.3.1 are now available
