CorOS 1.3.3 is now available
CorOS 1.3.3 is now available. Download it via Settings > Device Options > Device Updates on your Quad Cortex once connected to Wi-Fi. We recommend that you create a backup before updating your firmware.
Changelog
An issue where Neural Captures would be erased after using the Swap function in the Directory.
A crash that would occur after downloading a large backup multiple times in a row.
An issue where delay trails are broken when the Analog Delay’s or Slapback Delay’s bypass parameter is assigned to Scenes and the bypass/enabled state is controlled by Scenes.
A crash that would occur when turning an unused encoder with the IO Settings open immediately after booting.
An issue where the Master Volume defaults to an incorrect value after setting the volume below 100, power cycling, and locking the Quad Cortex.
An issue where the signal would be muted during Neural Capture calibration with certain Grid and IO Settings configurations.
An issue where the footswitch LEDs were not illuminated when the Device Options > Brightness screen was open.
An issue where incorrect Captures would display in the list of Neural Captures when replacing a device with a Neural Capture and Quad Cortex recalls the last bank accessed.
An issue where the Parametric-3 and Parametric-8’s On/Off and Band Type parameters could not be Scene-assigned.
An issue where Synth/Drone Presets would produce no output signal due to the Gain device’s Level parameter being set to -55.0db.
Minor backend performance issues.
