Nano Cortex® User Manual 2.2.0
Welcome to Nano Cortex
Neural DSP® Nano Cortex® User Manual [NanOS 2.2.0]
NC ModelBack 001
Neural Capture, one of the hallmark features of Neural DSP’s hardware, is integrated into Nano Cortex. This proprietary technology can learn and replicate the sonic characteristics of any physical amplifier, cabinet, or overdrive pedal with unprecedented accuracy.
Build Presets by adding a Neural Capture, an IR Loader, and effects to your signal chain. Deeper Preset customization and additional features are available via the Cortex Cloud app.
  • Neural Capture
  • 64 Preset slots
  • 25 Capture slots organized in 5 banks
  • 5 IR slots
  • 5 Effect slots that can be used separately or combined
  • MIDI support and Bluetooth connectivity
  • Access to thousands of Neural Captures on the Cortex Cloud app
Cortex Cloud
Discover Users and Neural Captures using the Cortex Cloud app.
Contact Information
Neural DSP Technologies is happy to provide professional technical support via email to all registered users, absolutely free of charge. Before contacting us, we recommend searching our knowledge base to see if the answer to your question has already been published.
If you cannot find a solution to your problem, please contact support@neuraldsp.com so we can help you further.
Nano Cortex weighs 620 g / 1.36 lbs and its dimensions are 14.4 x 10.3 x 6.2 cm / 5.6 x 4.0 x 2.4".
Nano Cortex Dimensions
Top View
NC TOP 3b
Rear View
NC BACK 4a
Side View
NC SIDE 3b
Quick Start Guide
NC QSG 004
Turning on your Nano Cortex
Connect your Nano Cortex to the power source.
Booting Sequence 01
After a few seconds, the BANK, CAPTURE, FX, and IR LEDs will light up indicating that Nano Cortex is powering on.
Booting Up New
Once the booting sequence completes, Nano Cortex will enter Performance Mode.
POWER SOURCES
Nano Cortex can be powered by two different sources:
  • EXTERNAL POWER SUPPLY: Nano Cortex requires a center-negative power supply that provides 9-12V DC and at least 600mA, using a standard 2.1/5.5mm DC connector. The Quad Cortex Power Supply is also compatible.
  • USB-C: Nano Cortex can also be powered via USB-C (5V-1.5A). Connect the unit to your computer or another USB-C compliant power source with the included USB-C cable.
USB-C Compliant Power Sources
To ensure optimal performance and safety, please use a USB-C power source that complies with the following specifications: 5V - 1.5A.
While connecting Nano Cortex to USB-A ports will allow for data transmission, these ports will not provide sufficient power to fully operate the device. Using USB-A ports or non-compliant USB hubs may result in improper functionality. Always verify that the USB-C source meets these requirements to maintain the longevity and reliability of your device.
Turning off your Nano Cortex
NC OFF2
Disconnect the Nano Cortex from the power source to power off the device.
Connecting your Gear
GEAR WIREFRAME 1 V4
Connect your instrument to INPUT.
Connect your studio monitors, PA, or FRFR cabinet to OUTPUT 1L and 2R. Additionally, you can connect your Headphones to HP OUTPUT.
GEAR WIREFRAME 2 V3
If your Nano Cortex is part of a bigger pedalboard setup, use INPUT and OUTPUTS 1L/2R to place it wherever you need it in the audio chain.
Global Controls
CAPTURE GLOBAL CONTROLs B2
Turn GAIN, BASS, MID, and TREBLE knobs clockwise and counterclockwise to control the Capture parameters.
Turn LEVEL to control the master output volume (OUTPUT 1L and 2R).
Use the HP OUT knob on the back to control the headphones output volume.
Bank Cycle V3
Press BANK to cycle through Capture banks.
CAPTURE SLOTS V8
Turn Footswitch Iclockwise or counterclockwise to navigate Capture slots.
All the LEDs will turn on when using a Neural Capture from the library that is not currently assigned to any slot.
Navigate to the last position, where the LEDs are not lit, to bypass the Neural Capture.
Preset AB V3
Press Footswitch I to toggle between Presets IAand IB. Different Presets can be assigned on the Cortex Cloud app.
Preset IIBA
Press Footswitch II to toggle between Presets IIA and IIB. Different Presets can be assigned on the Cortex Cloud app.
FX Cycle V4
Press FX to cycle through effect slots. Press-and-hold FX to bypass/enable the currently selected effect.
FX AMOUNT V4
Turn the AMOUNT knob clockwise or counterclockwise to change how much of the selected effect is applied.
IR SLOTS V8
Turn Footswitch II clockwise or counterclockwise to navigate IR slots.
All the LEDs will turn on when using an IR from the library that is not currently assigned to any slot.
Navigate to the last position, where the LEDs are not lit, to bypass the IR Loader.
Tunner Access 004
Press-and-hold Footswitch II for 2 seconds to access the Tuner. Press Footswitch II to exit the Tuner.
Action Buttons V6b
EXIT, CAPTURE, and SAVE buttons are reserved for the Neural Capture process, Preset saving, and Bluetooth pairing.
Neural Capture Quick Guide
Frame 1179
Neural Capture is a powerful tool that can learn and replicate the sonic characteristics of any amplifier, cabinet, or overdrive pedal with unprecedented accuracy and realism.
To create a Neural Capture, connect Nano Cortex to an overdrive pedal, a mic’d up cabinet, or an amplifier via a reactive load box.
Quick Connection Diagram
Capture Mode V6
Press CAPTURE to access Capture Mode. In this mode, the CAPTURE LED ring will stay on.
01 REFERENCE INSTRUMENT
02 MONITORING DEVICES
Connect your headphones to HP OUTPUT or your Monitor Speaker to OUTPUT 1L.
03 TARGET DEVICE
Connect the Nano Cortex's OUTPUT 2R (CAPTURE OUT) to the target device's input.
04 RETURN TO NANO CORTEX
Connect the target device's output to the Nano Cortex's CAPTURE INPUT.
05 CAPTURE INPUT GAIN
CAPTURE GAIN V6
Set the CAPTURE INPUT level by adjusting the GAIN knob.
06 CAPTURE
CAPTURE START V6
Press-and-hold CAPTURE for 3 seconds to begin the Capture process.
CAPTURE Progress V6
The CAPTURE LED ring will light up progressively as soon as the process begins.
07 TEST & SAVE
Capture AB Controls 003
Press Footswitch I to toggle between the Neural Capture and the Target Device.
Preset Saving V3
Press SAVE to store the recently created Capture. Choose a BANK, a Capture Slot, and press-and-hold SAVE for 3 seconds to store your Neural Capture.
Cortex Cloud App Pairing
BT 0035
BLUETOOTH PAIRING
BT Pairing 5
Open the Cortex Cloud app on your smartphone, access the Devices menu, and tap Add New. Your smartphone will start searching for nearby Nano Cortex units.
BT pairing short NEW
Press-and-hold EXIT and CAPTURE for 1 second to put your Nano Cortex into Pairing Mode.
The GAIN LED ring will illuminate clockwise and the Footswitch I's LED will blink slowly, indicating that Nano Cortex is in pairing mode.
BT Pairing Succesful 02
Once paired, the app will show the current Nano Cortex configuration.
EXIT v6
During Pairing Mode, press EXIT to return to Performance Mode.
Parameter Lock
It's possible to temporarily disable the rotary functionality of knobs and footswitches to avoid unwanted parameter switching when performing.
EXIT 3sec v6
Press-and-hold EXIT for 3 seconds to toggle the Parameter Lock.
LOCK LEDs v6
The EXIT LED ring will indicate when the Parameter Lock is enabled.
I/O Clipping Alert
The GAIN and LEVEL knobs will indicate whenever inputs or outputs are clipping.
PERFORMANCE MODE
Clipping IN
The GAIN Knob will blink 3 times whenever INPUT detects signal clipping.
Clipping OUT
The LEVEL Knob will blink 3 times whenever OUTPUTS 1L/2R detect signal clipping.
CAPTURE MODE
Locked Foots
The GAIN Knob will turn red whenever CAPTURE INPUT detects signal clipping.
Clipping OUT
Performance Mode
Performance Mode V4
Performance Mode Access
Performance Mode allows you to play with your instrument and process your signal. Nano Cortex will access Performance Mode automatically after booting up.
Signal Path
Nano Cortex processes your signal through a fixed audio chain consisting of different slots that can be used separately or combined.
NanOS 200 Signal Path 004
  • 2 Pre Effect slots
  • 1 Neural Capture slot
  • 1 IR Loader slot
  • 3 Post Effect slots
Performance Mode Controls
Global Controls Plus FX 1
  • GAIN: Sets the amount of gain for the current Neural Capture.
  • BASS: Sets the amount of bass frequencies for the current Neural Capture.
  • MID: Sets the amount of middle frequencies for the current Neural Capture.
  • TREBLE: Sets the amount of high frequencies for the current Neural Capture.
  • AMOUNT: Controls the amount of the active effect that is added to the direct signal.
  • LEVEL: Controls the master output volume (OUTPUTS 1L and 2R).
HP knobs 2
  • HP OUT: Headphones output volume control.
KNOB OPERATION MODES
Turn the knobs clockwise or counterclockwise to change their values.
Knob Modes V3
Nano Cortex's knobs are surrounded by LED rings, indicating their actual values regardless of the knobs' current positions.
By default, the Nano Cortex knobs adjust parameters immediately when turned. If the 'Catching Knobs Instantly' setting is disabled on the Cortex Cloud app, Nano Cortex will operate in Latching Mode, where the knobs' position must match the values indicated by the LED rings before they start adjusting parameters.
Capture Library
Nano Cortex includes 25 Factory Neural Captures organized in 5 banks. Each bank can store up to 5 Neural Captures.
BANK/SLOT NAVIGATION
BANK Cycle Expanded V3
Press BANK to cycle Capture Banks. The LEDs will light up according to the bank selected.
CAPTURE SLOTS V8
Turn Footswitch I clockwise or counterclockwise to navigate Capture slots. The LEDs will light up according to the slot selected.
CORTEX CLOUD LIBRARY
In addition to the 25 Factory Neural Captures, Nano Cortex can store up to 256 User Neural Captures that can be managed via the Cortex Cloud app.
IR Loader
Nano Cortex includes Factory Impulse Responses available via the 5 IR Loader slots.
IR NAVIGATION
IR SLOTS V8
Turn Footswitch II clockwise or counterclockwise to navigate IR Slots. The LEDs will light up according to the slot selected.
In addition to the 10 Factory Impulse Responses, Nano Cortex can store up to 256 User Impulse Responses that can be added via the Cortex Cloud website. Uploaded IR files will be stored in the "User Impulse Responses" folder.
Effects
NanOS 200 Effects 005
Nano Cortex includes 5 effect slots that can be used separately or combined.
EFFECT SLOTS NAVIGATION
FX Expanded V3b
Press FX to cycle through effects slots. LEDs will blink, indicating the slot that is currently selected.
FX Bypass V5
Press-and-hold FX to bypass/engage the currently selected effect slot. The LEDs will turn on/off, reflecting their current state.
BLOCK BYPASS V5
Bypassed effect slots will be turned off.
BLOCKS ON
Engaged effect slots will be turned on.
BLOCK 1 BLINK
The currently selected effect slot will blink.
FX AMOUNT V4
AMOUNT KNOB BEHAVIOR
The AMOUNT knob adjusts a predetermined parameter for the currently selected effect slot. The controlled parameter varies based on the selected virtual device.
Input Gate Control
Adjust the Input Gate's noise reduction amount in "Capture Volume & Input Gate" Mode (Hold CAPTURE for 2 seconds).
Switching & Saving Presets
By default, Nano Cortex offers quick access to four Presets that can be customized without using the Cortex Cloud app.
SWITCHING PRESETS
Preset AB V3
Press Footswitch I to toggle between Presets IA and IB.
Preset IIBA
Neural Capture, IR Loader, and Effect slots will update their values accordingly. Different Presets can be configured on the Cortex Cloud app.
Nano Cortex Footswitches Behavior
Presets on Nano Cortex are recalled when the footswitches are released, not when pressed.
This behavior enhances flexibility and control by allowing each footswitch to have multiple functions based on the press length. For instance, a short footswitch press-and-release recalls a Preset, while holding it down triggers a secondary function, such as opening the Tuner.
SAVING PRESETS
Preset Saving 2SEC
Press-and-hold SAVE for 2 seconds to overwrite the current Preset settings.
UNSAVED CHANGES
Dirty State V7
The SAVE LED ring will blink slowly whenever the current active Preset has unsaved changes.
EXIT v6
Press EXIT to undo unsaved changes.
CAPTURE VOL ACC 1
Press-and-hold CAPTURE for 2 seconds to enter Capture Volume & Input Gate Mode.
NanOS 200 Capture & Input Gate Mode 001
In this mode, the CAPTURE, LEVEL, and AMOUNT LED rings blink slowly.
KNOBS BEHAVIOR
NanOS 200 Capture Gate Mode 004
Turn the LEVEL knob to control the output volume of the Capture in the signal chain from -24dB to +12dB (0.0dB by default).
Turn the AMOUNT knob to control the Input Gate's noise reduction from 0% to 100%.
Nano Cortex's LEVEL knob Behavior
The Nano Cortex's LEVEL knob will operate in Latching Mode, meaning that its position must match the value indicated by its LED ring before it starts adjusting the output volume.
Preset Saving 2SEC
EXIT v6
Press EXIT to deactivate Capture Volume & Input Gate Mode.
Tempo
Tempo Mode allows you to set the tempo for time-synced virtual devices either by pressing Footswitch I or via the Cortex Cloud app. It can be configured globally or per Preset.
Tempo Access 001
While in Performance Mode, press-and-hold Footswitch I to access Tempo Mode.
TEMPO MODE
NC Tap Tempo Action 001
While in Tempo Mode, the Footswitch I LED will blink in time with the current tempo.
Press Footswitch I repeatedly to set the tempo. The time between presses determines the BPM value (beats per minute).
NC MIDI Clock IN
The Footswitch I LED turns blue when Nano Cortex receives MIDI Clock from a selected source (USB or TRS MIDI).
Tuner EXIT Stomp
Press Footswitch II to exit Tempo Mode.
App Synchronization
When Tempo Mode is engaged, the current Tempo settings are automatically displayed in the Cortex Cloud app (when connected and available).
Nano Cortex features a chromatic tuner. It works by detecting the note being played and then displaying its pitch deviation on the LED rings.
Tunner Access 005
While in Performance Mode, press-and-hold Footswitch II to access the Tuner.
TUNING DISPLAY
Tuner IN TUNE 01
The GAIN, BASS, MID, TREBLE, AMOUNT, and LEVEL LED rings will illuminate when a note is played, creating a crossfade animation that reflects the current pitch of the note (-/+ 50 cents).
Tuner Lights 2
The crossfade moves towards the left when the note is flat and to the right when it is sharp. When the note is in tune, MID and TREBLE will blink quickly.
Tuner MUTE Switch 1sec
Press-and-hold Footswitch II for 1 second to mute/unmute the input signal when the Tuner is engaged.
Tuner EXIT Stomp
App Synchronization
When the Tuner is engaged on device, it automatically displays on the Cortex Cloud app (when connected and available).
Capture Mode
Capture Mode V8
Neural Capture is a powerful tool that can learn and replicate the sonic characteristics of any amplifier, cabinet, or overdrive pedal with accuracy and realism.
Neural Capture Version 1 is our original Neural Capture algorithm, trained directly on your device in just a few minutes. This is the fastest and most lightweight way to create Neural Captures, ideal when you are on the go or without an internet connection. Perfect for capturing the sound of guitar amplifiers, combos, cabinets, and overdrives with remarkable accuracy.
Neural Capture Welcome 003
Creating a new Neural Capture is a procedure that can be completed on Nano Cortex without using the Cortex Cloud app.
To create a Neural Capture, you will need to connect an overdrive pedal, mic a cabinet, or connect an amplifier through a reactive load box to your Nano Cortex. Once created, it can be used in any Preset.
Nano Cortex's CAPTURE INPUT supports dynamic microphones. Condenser microphones will need an external preamp to be powered.
Tube Amplifier Warning
Connecting the speaker output of a tube amplifier directly to the Nano Cortex can cause serious damage to both devices. To ensure safe operation:
  • Use the D.I. output of the captured amplifier while keeping it connected to a speaker cabinet, or…
  • Connect a reactive load box between the amplifier’s speaker output and the Nano Cortex.
Capture Mode Access
Capture Mode V6
EXIT v6
Press EXIT to return to Performance Mode.
CAPTURE Process 01
CAPTURE Process 02
03 TARGET DEVICE
CAPTURE Process 03
Connect the Nano Cortex's CAPTURE OUT (OUTPUT 2R) to the target device's input.
CAP 004b
OVERDRIVE PEDAL
CAPTURE PEDAL B
If you are capturing an overdrive pedal, connect its output directly to the Nano Cortex's CAPTURE INPUT.
AMP+CAB / COMBO AMP
CAPTURE MIC B
Position a microphone in front of the speaker cabinet and connect it to Nano Cortex's CAPTURE INPUT. Nano Cortex's CAPTURE INPUT supports dynamic microphones. Condenser microphones need an external preamp to be powered.
AMP HEAD (NO SPEAKER)
CAPTURE LOADBOX C
If you are capturing an amplifier without built-in speakers or just an amp head, connect the amp's 'Speaker Output' to a Reactive Load Box. Then, connect the Load Box's balanced output to the Nano Cortex's CAPTURE INPUT.
05 SETUP REVIEW
Once everything is connected correctly, you can proceed with the calibration settings.
Neural Capture Calibration Settings
Capture Mode will give you access to the calibration settings.
Ensure the microphone position (if you are using a microphone in front of a speaker cabinet) and the target device's settings are set as desired, and the GAIN knob on the Nano Cortex is at the minimum position (0%).
MAIN CONTROLS
  • GAIN: Turn it clockwise to increase the CAPTURE INPUT gain up to +24dB. Its LED ring is a meter that measures the CAPTURE INPUT
  • LEVEL: Controls the overall output volume of the Nano Cortex (OUTPUT 1L and 2R).
  • FOOTSWITCH II: Turn it clockwise or counterclockwise to navigate IR slots. The LEDs will light up according to the slot selected. Navigate to the last position, where the LEDs are not lit, to bypass the IR Loader.
  • CAPTURE: Press-and-hold for 3 seconds to begin the Capture process.
ADDITIONAL CONTROLS
  • HP LEVEL: Headphones output volume control.
  • GND SWITCH: Toggles ON/OFF the ground lift on OUTPUTS 1L and 2R. This feature helps to reduce unwanted noise by interrupting the ground loops coming from external sources.
  • BOOST SWITCH: Toggles ON/OFF the analog boost circuit. When enabled, it boosts the CAPTURE INPUT +26dB.
GAIN KNOB BEHAVIOR
In Capture Mode, the GAIN LED ring is a meter that measures the CAPTURE INPUT.
CAPTURE GAIN V6
  • The GAIN LED ring will turn green when the CAPTURE INPUT level is healthy.
  • The GAIN LED ring will turn blue when the CAPTURE INPUT level is too low. Increase the GAIN or turn on the BOOST switch to compensate for the low level.
  • The GAIN LED ring will turn red and blink when the CAPTURE INPUT level is clipping. Turn off the BOOST switch or reduce the output level of the target device until the signal level is correct (Green LEDs).
Analog Boost Warning
Ensure the GAIN knob is set to its minimum position (0%) before engaging the BOOST switch.
Capture Process
CAPTURE START V6
Press-and-hold CAPTURE for 3 seconds to begin the Capture process. Alternatively, press EXIT to return to Performance Mode.
CAPTURE Progress V6
The CAPTURE LED ring will light up progressively as soon as the process begins. The Capture process takes around 5 minutes.
The Nano Cortex will measure the latency of the target device and deliver recorded signals that will be used for modeling. After the sanity check, Nano Cortex will train a neural network to emulate the tone and dynamic response of the target device.
Once the training process is complete, you will be able to test and save your Neural Capture.
Testing & Saving a Neural Capture
Once the Capture is completed, you can A/B compare the Capture and the target device.
Neural Capture Testing
A/B SWITCHING
When the Footswitch I’s LED bar turns green, it indicates that you are playing through the recently created Neural Capture. When the Footswitch I’s LED bar turns off, it indicates that you are playing through the target device.
IR LOADER
When auditioning a recently created Neural Capture, turn Footswitch II clockwise or counterclockwise to navigate IR slots. The LEDs will light up according to the slot selected.
Navigate to the last position, where the LEDs are not lit, to bypass the IR Loader (Recommended when auditioning a Capture that includes a speaker cabinet).
PEDAL BYPASS
Press Footswitch II to bypass the Nano Cortex.
CAPTURE SAVE V6
SAVING DESTINATION
The BANK and Capture Slots LEDs will blink indicating that you can select a slot to store your recently created Capture.
Bank Cycle V3
Press BANK to cycle Capture banks.
SAVING CAPTURE 03
The position where all LEDs are lit corresponds to the User Library. Choose this location to save the recently created Neural Capture without assigning it to any slot.
Preset Saving V3
Press-and-hold SAVE for 3 seconds to store your Neural Capture in the selected slot.
RETURN TO CALIBRATION SETTINGS
EXIT v6
Press EXIT to return to the calibration settings and start a new Capture process.
Press EXIT again to return to Performance Mode.
Neural Capture Version 2 Player
Neural Capture Version 2 is an advanced evolution of Neural Capture trained via Cortex Cloud. This option provides even higher-resolution Captures, making it especially powerful for touch-sensitive devices like fuzzes, compressors, and certain styles of amps, while still excelling at everything that Neural Capture Version 1 does.
V2 Neural Captures Support
C2 Devices
NanOS 2.2.0 introduces support for V2 Neural Captures. With this update, you can browse, audition, and load V2 Neural Captures as part of any preset on your Nano Cortex.
Cortex Cloud Content
V2 Captures are currently available on the Cortex Cloud and downloadable content.
06
Cortex Cloud App
CORTEX CLOUD HEADER V5
Cortex Cloud Features
Deeper Preset customization and additional features are available via the Cortex Cloud app:
  • Deeper Preset customization.
  • Additional Preset slots.
  • Additional IR Loader settings.
  • Impulse Responses Library.
  • Neural Capture metadata.
  • Thousands of Neural Captures from the community.
  • Create and restore Cloud Backups of your device.
Bluetooth Pairing
BLUETOOTH ACCESS
Cortex Cloud uses Bluetooth to pair with your Nano Cortex. First, allow Bluetooth access for the Cortex Cloud app in your smartphone’s settings.
PAIRING DEVICES
BT Pairing 5
PAIRING V6
BT Pairing 4b
The GAIN LED ring will illuminate clockwise and Footswitch I's LED will blink slowly, indicating that Nano Cortex is in Pairing Mode.
PAIRING A SECOND NANO CORTEX
Pairing 6
Go to the Devices menu and tap Add New. Your smartphone will start searching for nearby Nano Cortex units.
PAIRING V6
Press-and-hold EXIT and CAPTURE for 1 second to put your Nano Cortex in Pairing Mode.
Pairing 7 (rename)
Once paired, you can rename your Nano Cortex unit for future reference.
After that, the app will show the current Nano Cortex configuration.
EXIT v6
During Pairing Mode, press EXIT to return to Performance Mode if you no longer want to pair your device.
Devices Screen
Device Screen 004
Select the Neural DSP device you are currently using. Cortex Cloud will show only content compatible with your selection:
  • QUAD CORTEX: Cortex Cloud will show Quad Cortex-compatible content, such as Presets, Neural Captures, and Users.
  • NANO CORTEX: Cortex Cloud will show Nano Cortex-compatible content, such as Neural Captures and Users.
Downloading Content
BT Pairing 5
Ensure you have selected Nano Cortex in the Devices screen.
NEURAL CAPTURES
HOME SEARCH 1
Search for Neural Captures via Cortex Cloud.
AUDITION CAPTURE 1
Tap the Play button next to any Neural Capture or Impulse Response to audition it, allowing you to try content without having to store it on your device.
NC Audition LEDs
When auditioning, the Capture or IR slots on your device will slowly pulsate depending on the content type.
AUDITION CAPTURE 2
To stop auditioning, press EXIT on the device or tap Stop on the Cortex Cloud app.
The Nano Cortex can cache multiple Captures or IRs at once, allowing instant switching between them after the initial load (Indicated by a blue dot).
DOWNLOAD CAPTURE 1
Tap the download button next to the Neural Capture to store it on your device.
DOWNLOAD CAPTURE 2
The Neural Capture will then be downloaded to the Library. Alternatively, you can assign it to a bank and a slot.
DOWNLOAD CAPTURE 3
Assigning a Neural Capture to an occupied slot will replace the currently assigned Neural Capture.
DOWNLOAD CAPTURE 4b
Neural Captures downloaded while Nano Cortex is offline will be stored in the Downloads History under your Profile.
UPLOADING IMPULSE RESPONSES
Impulse Responses can be added to your Profile via the Cortex Cloud Website.
  1. Go to https://cloud.neuraldsp.com/cloud
  2. Access your Profile on Cortex Cloud.
  3. Go to the IMPULSE RESPONSES section.
  4. Drag-and-drop IR files from your computer to the upload area. Alternatively, click BROWSE to search for custom locations.
IR Compatibility 3
ADDING IMPULSE RESPONSES
DOWNLOAD IRS 1
Access your Profile and tap Impulse Responses.
UPLOAD IR 3
Tap the button next to the IR files to download them to your Nano Cortex.
Presets Library
Nano Cortex can store up to 64 Presets that can be assigned to Footswitch I and II or triggered via MIDI.
PRESETS 0003
SHOW ALL PRESETS will display all the Preset slots on a single screen.
PRESETS WORKFLOW
PRESET 01
Tap a Footswitch-assigned Preset to load it.
PRESET 02
Tap an unassigned Preset to load it. Footswitch I will turn red indicating the current Preset is not assigned to any Footswitch.
PRESET 03
Tap the button to the right of any Preset to access its contextual menu:
  • RENAME PRESET: Tap to rename the selected Preset.
  • DELETE PRESET: Tap to delete the selected Preset.
  • ASSIGN TO FOOTSWITCH: Tap to assign or reassign the selected Preset to any Footswitch.
Preset Multi Footswitch
You can assign a single Preset to multiple footswitches simultaneously.
NC Lifted preset
Tap-and-hold a Preset, then drag-and-drop it to reassign it to a different Preset slot. MIDI CC assignments remain unchanged, so reassigned Presets will inherit the CC of their new slots.
PRESET 04
Tap an empty Preset to load it. Alternatively, tap Create New Preset... to create a new Preset from scratch. Select at least one device and tap SAVE.
PRESET 05
Tap the PC/CC button at the top-right corner to toggle the PC messages view in the Presets list.
Neural Capture Library
NCapture Screen 04
SHOW ALL BANKS will expand all the Capture banks on a single screen.
NEURAL CAPTURE LIBRARY WORKFLOW
Capture Volume Slider 01
Drag the CAPTURE VOLUME slider to control the output volume of the currently active capture slot (-24dB to +12dB).
NCAP Swipe 01
Swipe horizontally to navigate Capture banks.
NCAP Slot 1
Tap an inactive Capture slot to activate it.
NCAP Details 01
Tap an active Capture slot to access its details screen.
NCAP Swap 01
Tap the swap button to the right of an active Capture slot to access the Capture Library and replace the currently loaded Neural Capture.
NCAP Swap 2
Tap a Neural Capture to audition it. Tap USE to load it in the current slot.
NCAP Bypass 01
Tap the Bypass button to bypass the Neural Capture module.
NEURAL CAPTURE DETAILS SCREEN
NCAP Details Screen V6
  • EXIT: Tap to return to the Capture Library.
  • EDIT: Tap to edit the details of the current Neural Capture. Not available when checking Neural Captures from other users.
  • CONTEXTUAL MENU: Tap to DELETE or SHARE the current Neural Capture.
  • OWNER/NAME: Tap to access the Neural Capture owner's profile.
  • ICON/COVER: Neural Capture's icon and custom cover photo are shown here.
  • DESCRIPTION FIELD: Neural Capture description and creation date.
  • UPLOAD TO CLOUD: Tap to upload the current Neural Capture to the Cloud. Not available when checking Neural Captures from other users.
  • VISIBILITY: Tap to toggle the current Neural Capture visibility (Private/Public). Not available when checking Neural Captures from other users.
  • PREFERRED INSTRUMENT: The preferred instrument is displayed here.
  • GAIN: The gain value is automatically calculated after creating a Neural Capture. Based on how saturated the Neural Capture is, it is given a gain value of 1-10; 1 being a clean 10 and 10 being the most saturated distortion.
  • SEND TO A FRIEND: Tap to send the selected Neural Capture to a friend.
  • DOWNLOAD: Tap to download the current Neural Capture to the Nano Cortex Library.
IR Loader Library
IR Loader V6b
IR LOADER WORKFLOW
IR slot 1
Tap a disabled IR slot to activate it.
IR slot 2
Tap an active IR slot to enter its parameter screen.
IR slot 3
Tap the Bypass button to bypass the IR Loader.
IR LOADER PARAMETER SCREEN
IR Loader Screen V5
Microphones and Mic Position modules will not be available in the IR Loader parameter screen layout when using User Impulse Responses.
  • BYPASS: Tap to bypass/enable the IR Loader.
  • IMPULSE RESPONSE: Displays the currently loaded Impulse Response.
  • IR LIBRARY: Tap to access Factory and User Impulse Responses.
  • PHASE: Tap to invert the phase of the current IR.
  • UP/DOWN: Tap to navigate Impulse Responses.
  • MICROPHONES: Factory microphones list. Tap to select a microphone. This module will not be available in the parameter screen layout when using User Impulse Responses.
  • MIC POSITION: Six fixed positions for the currently selected microphone. Tap to select a position. This module will not be available in the parameter screen layout when using User Impulse Responses.
  • LEVEL FADER: Drag to increase/decrease the Impulse Response output volume.
  • HI PASS FADER: Increase to remove low frequencies from the Impulse Response signal.
  • LOW PASS FADER: Decrease to remove high frequencies from the Impulse Response signal.
Effects Library
CorOS 200 Effects Layout 008
EFFECTS LIBRARY WORKFLOW
FX Bypass Toggle 04
Tap the Bypass button to bypass/engage the current effect.
FX Block params access 03
Tap an effect slot to access its parameters screen.
Multi FX 001
Tap the PRE or POST sections at the bottom to navigate effects slots within the parameter screen.
Multi FX 002
Different virtual devices can be assigned to effects slots. Tap the virtual device tab to open the virtual device list.
Multi FX 003
Tap the arrows to navigate virtual devices.
FX Unsaved Changes 02
A white dot will appear at the top-left corner of an effect slot whenever there are unsaved changes in its parameter screen.
AMOUNT FX Update v1
Nano Cortex's AMOUNT and FX LEDs will update their values reflecting changes made on the Cortex Cloud app in real time.
New Neural Capture (App)
While you can create a Neural Capture without using the Cortex Cloud app, using the app offers a better, guided experience from start to end.
To create a Neural Capture, you need to be able to connect an overdrive pedal, mic up a cabinet, or connect an amplifier via a reactive load box.
Capture App 002
Tap the contextual menu button at the app's top-right corner, and select Create New Neural Capture to access the 'Connection Diagram' screen.
Capture Mode V6
Alternatively, press the CAPTURE button on your Nano Cortex while the Cortex Cloud app is open. The app will automatically skip the 'Connection Diagram' and enter the 'Calibration Settings' screen.
CONNECTION DIAGRAM SCREEN
Capture App Diagram 003
Follow the instructions on the screen. Tap NEXT to navigate through the connection steps.
Alternatively, tap SKIP to access the 'Calibration Settings' screen.
CALIBRATION SETTINGS SCREEN
Capture App Calibration Settings 002
Ensure the target device's settings are set to your liking and the Nano Cortex's GAIN knob is at the minimum position.
  • CAPTURE GAIN: Drag the slider to increase the CAPTURE INPUT gain up to a maximum of +24dB.
  • OUTPUT LEVEL: Drag to control the overall output volume of the Nano Cortex (OUTPUT 1L and Headphones).
  • IR LOADER: Tap to toggle the IR Loader bypass state.
  • IR SLOT: Tap to select the IR slot.
  • START CAPTURE: Tap to begin the Capture process.
CAPTURE PROCESS & METADATA
Capture App Process 001
While the Capture is in progress, you can add metadata to your Neural Capture such as Name, Type, Description, and Preferred Instrument.
Tap NEXT to access the 'Testing' screen.
TESTING SCREEN
Capture App AB Saving 001
  • NEW NEURAL CAPTURE: Tap to edit the Neural Capture metadata.
  • A/B COMPARE: Monitoring switch. Tap to toggle between the target device signal and the recently created Neural Capture. Additionally, you can set it to switch automatically every 2, 4, or 6 seconds.
  • SAVE TO SLOT: Tap to save the recently created Neural Capture to a Capture slot.
  • SAVE TO LIBRARY: Tap to save the recently created Neural Capture in your Library.
Once your Neural Capture is saved, tap DONE to exit Capture Mode.
Alternatively, tap CREATE ANOTHER CAPTURE to return to the 'Calibration Settings' screen.
Tempo (App)
Tempo offers seamless integration with the Cortex Cloud app, allowing time-based effects to sync with your performance directly on the app.
Tempo Access App 001
Tap the contextual menu button at the app's upper-right corner, and select Tempo.
TEMPO LAYOUT
Tempo App Layout 008
  • EXIT: Tap to exit.
  • BPM VALUE: Displays the current tempo in beats per minute. Tap to enter a precise value manually (Disabled when Nano Cortex receives MIDI Clock from a selected source).
  • TAP PAD: Tap rhythmically to set the tempo based on your timing. Each tap updates the BPM value in real time.
  • TEMPO KNOB: Adjusts the tempo manually by dragging the knob up and down.
  • TEMPO MODE: Choose whether the tempo applies globally across all Presets, or is stored and recalled individually per Preset.
Tuner (App)
The Nano Cortex is equipped with a chromatic tuner that provides seamless integration with the Cortex Cloud app.
Tuner Access App 2
Tap the contextual menu button at the app's upper-right corner, and select Tuner.
TUNER LAYOUT
Tuner Screen Layout 01
The chromatic tuner works by detecting the pitch of the note being played and then displaying it on the Nano Cortex LED rings and on the Cortex Cloud App.
  • EXIT: Tap to exit the Tuner.
  • TUNING DISPLAY: Displays the note being played and its current pitch.
  • FREQUENCY: Adjust the reference pitch from 400 to 480Hz (440Hz by default).
  • MUTE: Tap to mute/unmute the input signal when the Tuner is opened.
USB MIDI Out
Nano Cortex can send MIDI messages to external devices via USB-C when pressing footswitches or upon Preset load.
USB MIDI Out Access 001
Tap the contextual menu button at the app's upper-right corner, and select USB MIDI Out to access the settings.
PRESET LOAD
USB MIDI OUT Preset Screen 001
You can assign up to 12 MIDI messages per Preset that will be sent via USB simultaneously once a designated Preset is loaded.
  • EXIT: Tap to exit the USB MIDI Settings screen.
  • CURRENT PRESET: Tap to access the Preset List. Choose a Preset to assign MIDI messages to it. You can assign MIDI messages to multiple Presets.
  • ADD (+): Tap to create a MIDI message.
  • DELETE: Tap to delete a MIDI message.
  • TYPE: MIDI message type (CC or PC).
  • CHANNEL: MIDI message Channel (1 to 16).
  • MIDI MESSAGE COMPONENTS:
    CC: CC# and Value.
    PC: Bank CC#0, Bank CC#32, and Program.
FOOTSWITCHES
USB MIDI OUT Footswitches Screen 002
You can assign up to 12 MIDI messages per footswitch that will be sent via USB simultaneously upon pressing a designated footswitch.
  • FOOTSWITCH: Tap to select a footswitch. The MIDI messages assigned to the selected footswitch will be displayed on the screen.
    CC: CC# and Value.
Incoming MIDI Support
Nano Cortex can receive MIDI messages from external devices via USB-C and TRS MIDI Type-A.
Settings Access 001
To enable incoming MIDI over TRS, tap the contextual menu button at the app's upper-right corner, go to 'Settings', and ensure the EXP/MIDI operation mode is set to MIDI.
PROGRAM CHANGE PRESET RECALL
PRESET 05
The Preset slots organized below 'ALL PRESETS' are automatically assigned to PC messages from Program 0 to 63. Tap the PC/CC button at the top-right corner to toggle the PC messages view.
USB MIDI ROUTING
USB MIDI Routing 001
  1. Connect your Nano Cortex to a computer via USB-C.
  2. Open your DAW and ensure Nano Cortex is recognized as a MIDI device.
  3. Create a MIDI Track, route its output to Nano Cortex, and place Program Change messages in a MIDI clip.
  4. Nano Cortex will recall Presets from the Preset Library accordingly upon playback.
Windows® ASIO® Driver
For USB functionality on Windows® computers, you must download and install the Nano Cortex ASIO® driver from our website. No driver installation is required for Mac® computers.
TRS MIDI TYPE-A ROUTING
TRS MIDI ROUTING 002
  1. Ensure the EXP/MIDI operation mode is set as MIDI in the 'Nano Cortex Settings' screen.
  2. Connect the external MIDI device's MIDI OUT to Nano Cortex's EXP/MIDI input by using a TRS MIDI Type-A cable.
  3. Set the external MIDI device to send Program Change messages (Program 0 to 63).
  4. Nano Cortex will recall Presets from the Preset Library accordingly.
TRS MIDI TYPE-A SUPPORT
TRS MIDI Support 2
The TRS MIDI Type-A connection is the official standard adopted by the MIDI Association. Nano Cortex's EXP/MIDI input will be compatible with any TRS MIDI cable that meets the following requirements:
  • TIP: Data line (MIDI Din Pin 5).
  • RING: Voltage reference line (MIDI Din Pin 4).
  • SLEEVE: Shield line (MIDI Din Pin 2).
Incoming MIDI CC List
The following MIDI Continuous Controller (CC) messages are reserved for direct control of Nano Cortex parameters:
EXPRESSION PEDAL CONTROL
  • CC#1: Expression Pedal position.
    • Value 0: Heel Position.
    • Value 127: Toe Position.
SLOT BYPASS
  • CC#34: INPUT GATE Slot bypass.
    • Value 0-63: Off.
    • Value 64-127: On.
  • CC#35: CAPTURE Slot bypass.
    • Value 0-63: Off.
    • Value 64-127: On.
  • CC#36: CAB/IR Slot bypass.
    • Value 0-63: Off.
    • Value 64-127: On.
  • CC#37: FX Slot 1 bypass.
    • Value 0-63: Off.
    • Value 64-127: On.
  • CC#38: FX Slot 2 bypass.
    • Value 0-63: Off.
    • Value 64-127: On.
  • CC#39: FX Slot 3 bypass.
    • Value 0-63: Off.
    • Value 64-127: On.
  • CC#40: FX Slot 4 bypass.
    • Value 0-63: Off.
    • Value 64-127: On.
  • CC#41: FX Slot 5 bypass.
    • Value 0-63: Off.
    • Value 64-127: On.
UTILITY CONTROL
  • CC#42: Tap Tempo control.
    • Value 0-127: Tap.
  • CC#43: Tuner access.
    • Value 0-63: Tuner Off.
    • Value 64-127: Tuner On.
Cloud Backups
The Cortex Cloud app allows you to create up to five Cloud backups of the items and device settings of your Nano Cortex, including Presets, Neural Captures, and Impulse Responses.
NC Cloud Backups Access 1
Tap the contextual menu button at the app's upper-right corner, and select Backups.
CREATING A CLOUD BACKUP
Follow these steps to create a Cloud backup of your Nano Cortex:
  1. Pair your Nano Cortex with your Cortex Cloud app.
  2. Tap the contextual menu button at the app's upper-right corner, and select Backups.
  3. Tap CREATE NEW CLOUD BACKUP.
The SAVE LED ring will spin until the Cloud backup process is completed.
CLOUD BACKUP OPTIONS
Tap the button to the right of any Cloud backup to access additional options:
  • EDIT NAME: Tap to rename the selected Cloud backup.
  • UPDATE: Tap to update a previously made Cloud backup with the current items and device settings.
  • DOWNLOAD: Tap to download the selected Cloud backup to your Nano Cortex.
  • DELETE: Tap to delete the selected Cloud backup.
Warning!
Downloading a Cloud Backup will overwrite all the content and settings stored on your device.
Expression Pedal Configuration
Many of Nano Cortex's parameters can be controlled externally via any compatible expression pedal.
Settings Access 001
To enable expression pedal support, tap the contextual menu button at the app's upper-right corner, go to 'Settings', and ensure the EXP/MIDI operation mode is set as EXPRESSION PEDAL.
EXPRESSION PEDAL CALIBRATION
EXP Calibration 04
To ensure Nano Cortex responds to your expression pedal’s full sweep range, it may be necessary to calibrate it during the first use via the Settings screen.
  1. Place the expression pedal on the surface where it will be used and connect it to the Nano Cortex's EXP/MIDI input using a TRS cable.
  2. Tap RECALIBRATE.
  3. HEEL TOE Switch 02Rock the expression pedal back to its heel position and all the way down to its toe position.
  4. Tap SAVE.
Expression pedal calibration settings remain active until a new calibration is performed.
EXPRESSION PEDAL ASSIGNMENTS
Exp Pedal Assign Access 3
Tap the contextual menu button at the app's upper-right corner and tap Expression Pedal.
You can assign an expression pedal to control the range and bypass state of multiple parameters.
  • PARAMETER RANGE
EXP RANGE CARD 1
GAIN, BASS, MID, TREBLE, AMOUNT, and LEVEL knobs.
  1. Tap the parameters you want to control via the expression pedal. Multiple parameters can be assigned at the same time.
  2. By default, the expression will range from 0 to 100%. Drag the edges of the bar to limit its range.
  3. Tap the top-right button to reverse the expression behavior, swapping the heel and toe positions.
  4. Alternatively, tap the top-left button to delete the assignment.
  • SLOT BYPASS
EXP BYPASS CARD 2
CAPTURE, IR LOADER, and EFFECTS slots.
  1. Tap the parameters you want to bypass via the expression pedal. Multiple parameters can be assigned at the same time.
  2. Tap the 'Switch on' field to navigate through bypass modes.
    SWITCH: Pressing the expression pedal toe switch will bypass/engage the slot. Activate the Latch Emulation feature to modify the behavior of momentary toe switches, emulating a latching response.
    STOP: Keeping the expression pedal still will bypass the slot. Drag the SWITCH DELAY bar to set the time it takes for the slot to be bypassed.
    HEEL-TOE: The slot will be bypassed when the expression pedal is at heel position. Drag the SWITCH DELAY bar to set the time it takes for the slot to be bypassed (up to 2000ms).
EXPRESSION PEDAL SUPPORT
Nano Cortex is compatible with any expression pedal that meets the following requirements:
  • TRS CONNECTOR: Single TRS expression output. Wah or Volume outputs are not supported.
  • CURVE: Pedals with linear and logarithmic curves will work properly after being calibrated during the first use.
  • TOE-SWITCHES: Optional feature. Latching and Momentary switches are supported. Momentary switches will work only when the Nano Cortex Latching Emulation feature is active.
  • ADDITIONAL CONTROLS: Optional feature. Range control knobs and polarity switches are also supported.
Firmware Updates
Nano Cortex's operating system is called NanOS. Keeping NanOS up to date improves the functionality, security, and overall user experience of your Nano Cortex.
BT Pairing 4
Ensure that the Nano Cortex is properly paired with your smartphone and that your Internet connection is stable.
UPDATE PROCESS
Nanos Update Banner 001
A banner will appear at the top of the app screen whenever a NanOS update is available.
  1. Tap Update at the right side of the banner.
  2. Follow the instructions on screen. Tap UPDATE to start the download process.
Update LED Loop 003
Nano Cortex's BANK and CAPTURE LEDs will reflect the download progress. Once the download completes, please wait a few minutes for your Nano Cortex to finish the installation.
After the setup, Nano Cortex will reboot and automatically reconnect to your smartphone.
Firmware Update Warning
The NanOS update process may take a few minutes to complete.
Ensure your Nano Cortex is close to your smartphone during this process. To prevent installation issues, avoid locking your smartphone, disabling Bluetooth, minimizing or closing the Cortex Cloud app during the update.
The Settings screen allows you to control most aspects of your Nano Cortex.
Settings Access 001
Tap the contextual menu button at the app's upper-right corner and tap 'Settings' to access the Nano Cortex Settings screen.
NANO CORTEX SETTINGS SCREEN
  • DEVICE NAME
Settings Device Name 2
Assign a custom name for your Nano Cortex (up to 22 characters).
  • STORAGE
Settings Storage 2
Available storage on your Nano Cortex.
  • LED BRIGHTNESS
Settings Brightness 2
Drag the slider to set the LED brightness of your Nano Cortex (60% by default).
  • USB PLAYBACK VOLUME
Settings USB Playback
Drag the slider to set the USB playback volume (-6.0dB by default).
  • ANALOG OUTPUTS AUTO-SUM
Nano Auto Sum Switch
When Auto-Sum to Mono is enabled, Nano Cortex will automatically sum its output to mono when only one audio cable is inserted into either Output 1L or Output 2R. This setting affects the behavior of all the stereo effects in the signal path, such as panning and time effect trails.
  • PRESET OPERATION MODE
Settings Preset Mode 2
Enable 4-Preset Mode to assign Presets to both Footswitches I and II (IA, IB, IIA, and IIB).
If this setting is disabled, Nano Cortex will operate in 2-Preset Mode, allowing only Footswitch I to recall Presets (A and B) while Footswitch II will function as a global bypass switch.
  • KNOB OPERATION MODE
Settings Knobs Mode 2
By default, the Nano Cortex knobs adjust parameters immediately when turned. If this setting is disabled, Nano Cortex will operate in Latching Mode, where the knobs' position must match the values indicated by the LED rings before they start adjusting parameters.
  • IR BYPASS
Settings IR Byass
Bypasses the IR Loader on the selected outputs (1L, 2R, or Global Bypass). Useful when using Nano Cortex with a guitar cabinet or external speaker simulation system.
  • TRAILS
Settings Trails
Enables delay and reverb trails when bypassing Nano Cortex. This setting has no effect in 4-Preset Mode.
  • EXP/MIDI INPUT BEHAVIOR
Settings EXPMIDI IN 2
  • INPUT MODE: Tap to toggle the EXP/MIDI input between Expression Pedal and MIDI Input functionality.
  • RANGE CALIBRATION: Tap 'Recalibrate', then move the expression pedal from the heel to the toe position. Once the full sweep is completed, tap 'Save' to store the calibration.
  • MIDI CHANNEL: Sets the Nano Cortex base MIDI channel.
  • MIDI THRU: Enable to forward MIDI messages received via the TRS MIDI input directly to the USB MIDI output.
  • MIDI CLOCK SOURCE: Choose the source for incoming MIDI Clock signals: OFF, USB, or TRS MIDI.
  • MONITORING OPTIONS
Settings Mute
Manage how audio is routed when using Nano Cortex as an audio interface via USB, preventing duplicate signals or feedback loops during reamping or DAW-based monitoring.
  • MUTE GUITAR INPUT: Mutes the analog INPUT to the signal chain, preventing direct monitoring through Nano Cortex. USB INPUT 1 remains active. This is useful when reamping through USB OUTPUT 3.
  • MUTE GUITAR OUTPUT: Mutes the analog audio sent from the signal chain to OUTPUTS 1L/2R. USB audio playback from your DAW still passes through. Ideal for monitoring processed audio exclusively via your DAW.
  • ABOUT
Settings Firmware Version 2
Current NanOS version and device serial number. The Nano Cortex serial number is also engraved on the bottom of the device.
  • FACTORY RESET
Settings Factory Reset 2
Performing a factory reset will remove all user content from the device.
07
Computer Integration
Nano Cortex can function as an audio interface by connecting it to your computer via USB.
COMPUTER HEADER V1
USB Audio Setup
Nano Cortex can be utilized as a USB 2.0, 24-bit, 48kHz (Fixed), low-latency audio interface for Windows® and Mac® computers.
Connect your Nano Cortex to your computer via the USB-C cable included in the box.
MACOS® SETUP
  1. Connect your Nano Cortex to your computer.
  2. Go to 'System Preferences', 'Sound', and set Nano Cortex as the main Input and Output device of your computer.
WINDOWS® SETUP
  1. Download the driver installer from our website (Downloads).
  3. Connect your Nano Cortex to your computer.
  4. Go to 'Control Panel', 'Hardware and Sound', 'Sound', and ensure your Nano Cortex is set as the default Playback and Recording device of your computer.
The Nano Cortex driver will be installed in the following path location: C:\Program Files\NeuralDSP\Nano Cortex Driver
USB Channels
Nano Cortex features 7 USB Channels (4IN/3OUT).
USB MATRIX V4
Host Monitoring
D.I. and processed signal recording
Nano Cortex allows you to record dry and processed signals simultaneously. Connect your instrument to INPUT and ensure Nano Cortex is selected as the default audio interface on your computer.
USB DAW 3
  2. Create a stereo audio track and set its input as Input 3/4 (Processed signal from analog OUTPUT 1L and 2R).
  4. To reamp a recorded D.I. track, set its output as Output 3 (To Nano Cortex's INPUT), create a new stereo track (Input 3/4), and arm it for recording.
Connecting Nano Cortex to an iPhone® or iPad®
USB IPHONE 1
You can use any class-compliant USB audio device with an iPhone® or iPad®. Nano Cortex can be connected to those devices via a USB-C cable (iPhone 15 or later).
iPhone 14 and older generations will need the Apple® Lightning to USB-C Camera Adapter to recognize Nano Cortex as an external microphone device.
This feature allows you to use Nano Cortex with audio apps like GarageBand® for recording purposes.
08
Additional Information
Specs V3
Virtual Device List
nc-virtual-device-200
All product names are trademarks of their respective owners, who are not associated or affiliated with Neural DSP in any way. The displayed names are used solely to identify the specific products that were studied during the development of virtual devices.
Factory Reset
Factory Reset 1
Press-and-hold EXIT, CAPTURE, and Footswitch II for 2 seconds.
Factory Reset 2
The LEDs will light up. GAIN, Footswitch I and II will turn blue.
Calibration 004
While the LEDs are lit, press-and-hold SAVE until the Nano Cortex reboots. All user data will then be removed.
Warning!
Performing a factory reset will remove all user content, including Neural Captures, Presets, and Impulse Responses from your device. This action cannot be undone.
Hardware Specifications
INSTRUMENT INPUT
  • CONNECTOR: 1/4 TRS-F
  • IMPEDANCE: 1MΩ
  • MAX INPUT LEVEL: +10dBu
COMBO CAPTURE INPUT
  • CONNECTOR: XLR-F + 1/4 TRS-F
  • TS IMPEDANCE: 1MΩ
  • XLR IMPEDANCE: 45kΩ
  • BOOST GAIN: +26dB
TRS OUTPUTS 1L/2R
  • CONNECTOR: (2) 1/4 TRS-F
  • IMPEDANCE: 560Ω
  • MAX OUTPUT LEVEL: +10dBu (Unbalanced) / +16dBu (Balanced)
HEADPHONES OUTPUT
  • CONNECTOR: 3.5MM TRS-F
  • MAX OUTPUT POWER: 55mW into 20Ω
EXP/MIDI INPUTS
  • EXPRESSION CONNECTOR: 1/4 TRS-F
  • MIDI CONNECTOR: MIDI TRS Type A
USB AUDIO
  • CHANNELS: 7 (4IN/3OUT)
  • AUDIO CLOCK: 48 kHz (FIXED)
GENERAL
  • CONTROLS:
    2 Stainless Steel Stomp + Rotary Footswitches
    7 Knobs
    2 Analog Switches
    5 Digital Switches
  • DIMENSIONS: 14.4 x 10.3 x 6.2 cm / 5.6 x 4.0 x 2.4"
  • WEIGHT: 620g / 1.36lbs
  • INPUT VOLTAGE:
    9-12V DC 600mA (Center Negative)
    USB-C 5V, 1.5A or higher
ENVIRONMENTAL INFORMATION
  • OPERATING TEMP: 0 to 50 °C (32 to 122 °F)
  • STORAGE TEMP: -10 to 70 °C (14 to 158 °F)
Disclaimer
In the interest of continuous improvement, specifications for the Nano Cortex are subject to change without notice. For any questions, please feel free to contact us at support@neuraldsp.com.
(1) This device may not cause harmful interference, and
(2) this device must accept any interference received, including interference that may cause undesired operation.
This equipment complies with FCC and IC radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance of 20 cm between the radiator and your body.
This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation.
(1) l'appareil ne doit pas produire de brouillage, et
(2) l'utilisateur de l'appareil doit accepter tout brouillage radioélectrique subi, même si le brouillage est susceptible d'en compromettre le fonctionnement.
This Class B digital apparatus complies with Canadian ICES-003.
Cet appareil numérique de la classe B est conforme à la norme NMB-003 du Canada.
Neural DSP®, Neural Capture®, Capture®, Quad Cortex®, Nano Cortex®, Archetype®, Algorithmically Perfect®, and Nameless® are registered trademarks of Neural DSP Technologies Oy.
