CorOS 3.0.1 and Cortex Control 1.1.1 are now available
We are pleased to announce that CorOS 3.0.1 and Cortex Control 1.1.1 are now available!
We recommend that you create a backup before updating your firmware. We recommend you read this post before updating.
Cortex Control can be downloaded from the Downloads page.
CorOS 3.0.1 Changelog
Renamed the ‘Source’ parameter for the Doubler and Plugin Doubler devices and added a tooltip in the parameter editor for both devices.
An issue where an unsaved Preset from an incorrect bank would load after reloading a Preset via the assigned footswitch in Preset Mode.
An issue where Neural Captures or Impulse Responses added to a folder were not visible after deleting items from the same folder using multi-selection or within Cortex Control.
An issue where copied Presets could not be pasted using two of the three pasting options when selecting the 'Paste Here' button without first selecting the Preset folder in the Directory.
An issue where large backups could not always be downloaded, and large bulk operations could not always be performed via Cortex Control.
An issue where the Plugin Blend’s and Transparent Blend’s wet signal bypassed the TUNER mute state when the Blend parameter was set to 100%.
An issue where no repeats occurred from the Gojira DLY block at certain tempos when SYNC was ON and the SYNC NOTE was set to a 1/xT subdivision.
An issue where no repeats occurred from the Plini Delay block at certain tempos when SYNC was ON and the SYNC NOTE was set to a 1/xT subdivision.
An issue where a UI crash would occur when uploading a Preset containing a user Capture if a Capture Cloud search request failed.
A UI crash that could occur when downloading multiple Captures from the Downloads folder within the Directory.
An issue where setting the Doubler source to "Off" would mute the output signal if the Doubler was only receiving input from the right side.
An issue where USB output meters would freeze and stop functioning shortly after pausing USB audio from a web browser into the Quad Cortex.
An issue where phasing and tonality differences occurred when multiple sets of inputs and outputs were used simultaneously on path 1 and path 2, compared to when used on path 1 and path 3.
An issue where a clicking sound could be heard when changing Scenes in a Preset with the Plugin Blend device after the Preset was saved.
An issue where the Doubler Spread parameter would have an incorrect default value after loading the Adaptive Gate (S/C) via the UP footswitch and then switching back to the Doubler via the UP footswitch.
An issue where the Quad Cortex would output audio only on the left channel when the Adaptive Gate S/C device was last in the signal chain with the source set to "Off".
An issue where a UI crash would occur when attempting to save a Neural Capture if the Captures Library was full.
An issue where the level measured for a mono FX Loop Return device was 3dB lower than when using a stereo FX Loop Return device.
Cortex Control 1.1.1 Changelog
An issue where Cortex Control got stuck on the "Loading Preset..." screen after launching the application.
An issue where, when creating multiple Neural Captures in a row, the next Capture created was auto-named incorrectly within the Neural Capture save menu.
An issue where device icons disappeared from the chain after clicking or dragging during device audition.
An issue where the "Next Device Model" and "Previous Device Model" shortcuts listed in the Help menu were opposite from their actual implementation.
An issue where the Splitter Parameter Editor did not correctly reflect the Mute state when Mute was set on Quad Cortex while Cortex Control was closed.
An issue where Path 3 and Path 4 could be hidden behind the Parameter Editor in Gig View when selecting Inputs or Outputs on Path 3 or Path 4.
An issue where a Neural Capture got duplicated if another device was clicked during an audition.
An issue where the wrong icon was shown the first time a Neural Capture was auditioned after launching Cortex Control.
An issue where in the Looper X Parameter Editor, after performing an Undo action and then pressing Play, the Redo icon reverted to an Undo icon.
An issue where Neural Capture devices displayed the default Capture icon after loading a Preset.
A crash that occurred after selecting the Search > Favorites > Recents menu in the Directory.
An issue where giving a Scene a blank name resulted in the Quad Cortex and Cortex Control showing two different names for the Scene.
An issue where it was possible to set an empty name for multiple devices in Stomp Mode’s Gig View.
An issue where the HPF and LPF appeared to be active when initially loading a Graphic-9 device, even though the parameter knobs were set to 'OFF'.
An issue where pinning a model while it was being auditioned and selecting it resulted in the wrong model being loaded.
An issue where output meters in the Grid were frozen upon opening or closing the I/O Settings.
An issue where the Global EQ lost sync with Quad Cortex if a high DSP preset was loaded while the EQ was open in Cortex Control.
An issue where, when a downloaded Preset was in Preview Mode, the Previous/Next Preset buttons did not cycle through the other Presets in the Downloads folder.
An issue where, when previewing or loading a device from preview that had its default settings changed, it would preview or load with its factory default settings.
An issue where stereo inputs, stereo outputs, and Multi Out could not be added to the Grid from within the menu that opens after selecting an empty input or output on the Grid.
An issue where an unsaved Preset was not loaded after clicking 'Create New Preset' in the Main Menu if there were no unsaved Presets in the My Presets folder.
An issue where some of the information in the Incoming MIDI Reserved CC list was incorrect.
